hwIWindow GetClientType
Returns the window client type.
hwIWindow_handle GetClientType
Tcl Query
Error
Success (0) or an error code.
Draws the client object.
Returns the client object handle.
Gets the height of the graphics window.
Gets the width of the graphics window.
Gets the window caption used when exporting to HTML.
Returns the window ID.
Returns the offset of a given window.
Returns the scale of a given window.
Returns the view control handle for the current client.
Gets the export file type for hwlSession_handle PublishSession.
Tests if the window is empty.
Sets the window client type.
Sets the window caption used when exporting to HTML.
Sets the offset of a given window.
Sets the scale of a given window.
Sets the export file type for hwlSession_handle PublishSession.
ON THIS PAGE
Tcl Query
ON THIS PAGE
