::hwp::getClosestNode
Finds the closest node for the specified point coordinates.
Tcl Query
This procedure implements minus options.
Mandatory Arguments
-xPos "x coordinate"
The x coordinate.
-yPos "y coordinate"
The y coordinate.
-zPos "z coordinate"
The z coordinate.
Optional Arguments
-componentId "component id"
The component ID.
-displayMode "all / displayed"
The display mode of the node to be searched (all or only displayed). Default is "displayed".
-radius "real number"
The sphere radius that is used to search the closest node (default = 10).
Returns
The node ID of the closest node to this position.
Examples
set noteId [::hwp::getClosestNode -xPos -750 -yPos 400 -zPos 220]
set noteId [::hwp::getClosestNode -xPos -750 -yPos 400 -zPos 220 -componentId 2000591 -displayMode displayed -radius 100]
