::hwp::GetRenderOptions
Gets a render options handle of an animation client.
Tcl Query
This procedure implements minus options.
This procedure returns a render options handle of HyperView.
If no page ID is requested, then it operates on the current/active page.
If no window ID is given, then it returns a note handle of the active window.
Mandatory Arguments
None.
Optional Arguments
-page "pageID"
The page ID of the requested page.
-window "windowID"
The window ID of the requested window.
Returns
Returns a render options handle of the animation client.
set renderOptionsHandle [::hwp::GetRenderOptions -page 2 -window 4]
