::hwp::GetComponent
Gets a component handle of an animation client model.
::hwp::GetComponent
Tcl Query
This procedure implements minus options.
This procedure returns a component handle of a HyperView model.
Mandatory Arguments
-id "componentID"
The component ID.
Optional Arguments
-modelId "modelId"
The model ID.
-poolType "pool type" (default Part)
The pool type of the component, for example "Part", "Orphan-Node", or other. Default value is "Part".
Returns
Returns a component handle of an animation client model.
set componentHandle [::hwp::GetComponent -id 2000591]
