::hwp::getMaxContourValue
Displays a contour result.
Tcl Query
This procedure implements minus options.
Mandatory Arguments
-resultArrayName "array_name"
The array name where the results of the search are stored.
Optional Arguments
None.
Returns
None. The return value is stored in the array provided under resultArrayName.
Examples
::hwp::getMaxContourValue -resultArrayName myArray
foreach name [array names myArray] {puts "$name $myArray($name)"}
