pltIMacro GetCurveAttachmentExpression
Finds the curve that a curve note is attached to.
pltIMacro_handle GetCurveAttachmentExpression
Tcl Query
This command finds the position curve that the curve note is attached to. The curve will be expressed as the exact position of the curve. For example, for a curve on the first page in the first window, the first curve would have the math reference p1w1c1.
Note: This function only works if there is a macro with a note that is attached to one of the curves.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm GetMacroHandle mc 1;
mc GetCurveAttachmentExpression;
Success (the curve position) or an error message is returned.
Keywords
Tcl
Macro
Note
Query
