pltIMacro SetCurveAttachmentExpression
Sets the curve that the curve note is attached to.
pltIMacro_handle SetCurveAttachmentExpression expr
Tcl Modify
This command sets the curve that the curve note is attached to. This function only works if there is a macro with a note that is attached to one of the curves.
- expr
- The expression (math reference) of the curve the you want to attach the note to. An expression usually states the exact location of the curve. For example, for a curve on the first page, in the first window, the first curve would have the math reference p1w1c1.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm GetMacroHandle mc 1
mc SetCurveAttachmentExpression p1w1c1
mc Apply original false
Keywords
Tcl
Macro
Note
Modify
