pltIMacro IsComplexNotePositionInROP
Checks if the position of the complex macro note is in the real or phase plot.
pltIMacro_handle IsComplexNotePositionInROP
Tcl Query
This command determines if the position of the complex macro note is in the real or phase plot. This function only works if there is a complex macro with a note. If the note is in the real or phase plot, then true is returned. If it is in the imaginary or magnitude plot, false is returned.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm GetMacroHandle mh 1;
mc IsComplexMacro;
Success (true or false value) or an error message is returned.
Keywords
Tcl
Macro
Complex Plot
Query
