Manage Repositories
Additional repositories, also known as data stores, can be added so that information stored in other locations, such as material databases or corporate PLM systems, can be retrieved directly from within the HyperMesh environment.
Out-of-the-box connectors are available for Teamcenter, Windchill and Total Materia. These connectors can be used if existing instances of one or more of these tools is available. When adding a new Total Materia repository, the host name is http://api.keytometals.com:8080/altair.
  1. Click Manage Repositories to add a new repository.
  2. Select the Type of repository.
  3. Click Register.
  4. Enter your information in the Value column.
  5. Click 適用.
  6. To make any changes, click Reset to clear your information or Discard to cancel and hide the Repository Details panel.
  7. Click OK to register your repository.
