Show/Hide Recycle Bin
The recycle bin works in much the same way as the recycle bin on the Windows operating system. Contents that have been deleted from the library are moved to the recycle bin.
基本について学習し、ワークスペースを理解します。
アプリケーションの起動と設定。
モデルの作成、オープン、インポート、および保存。
セッションを設定し、レポートテンプレートを作成します。
HyperMeshがサポートするソルバーインターフェース。
2Dパラメトリックスケッチ形状を作成/編集できます。
ジオメトリの作成、編集、クリーンアップ。
パートとサブシステムの作成、編成と管理。
HyperMesh複合材料のモデリング。
モデルのパート間に結合を作成します。
HyperMeshでの最適化セットアップ。
複数分野の設計探索および最適化のツール。
衝突および安全解析で使用するツール。
HyperMesh-Tclを使用して開発された各種ツール。
レポートの作成、定義、エクスポート。
Common terminology used with the collaboration features is described in this section.
Content refers to any information stored in a library. Content Definitions encapsulate information about the types of information managed by the HyperMesh libraries.
Use the Organize browser to organize your data.
There is one out-of-the-box repository, Personal (managed repository).
Libraries can be created within a repository to logically organize or group the contents stored within a repository. Repositories can contain one or more libraries.
A workspace is a local directory where files are retrieved from the vault so that they can be viewed and/or modified.
Content inside a library can be organized by folders and categories.
The Contentブラウザ is the main component of the Organize browser and displays library content in many ways, according to options available from the toolbar.
The Properties panel shows metadata names and values for the selected object in the Contentブラウザ.
Use the Contentブラウザ to set your preferences.
Use the Category view to view the library contents according to category. Use the Folder view to view the library contents according to what folders they reside in.
Contents that refer to other contents are indicated with the Show/Hide References icon.
For managed libraries it is possible to see all contents belonging to the library (Repository view) or only the content whose documents are retrieved in the current workspace (Workspace view).
Filter contents by using the Filter toolbar.
You can export and create a new library with selected contents from your active library.
Labeling is a convenient way to associate groups of related contents together so they can be easily retrieved and viewed as a set.
Lifecycle operations include operations such as Get, which retrieves a content to your workspace, and Check-Out and Check-In, which result in versioning of contents.
The Explore dialog provides enhanced capabilities for searching for and retrieving data, beyond what is provided from typical file browse dialogs.
Use the Subscribe dialog to register or subscribe to parts or items of interest that reside within a corporate PDM system. Once the parts have been subscribed to, the dialog helps to ensure that you are working with the latest information by allowing you to quickly check whether any subscribed to parts have been updated, and to seamlessly retrieve updated information and files for those that have.
MotionView supports a limited version of interface with Collaboration Tools.
Collaboration Tools comes with an out-of-the-box profile, which is tailored specifically for organizing and managing material information and data.
