HyperView ANSYS結果リーダー
サポートされる結果
| データ名 | 結果タイプ | Data Type |
| 構造 | ||
| acoustic pressure | NODE | VECTOR |
| displacement | NODE | VECTOR |
| velocity | NODE | VECTOR |
| acceleration | NODE | VECTOR |
| rotation | NODE | VECTOR |
| reaction force | NODE | VECTOR |
| reaction moment | NODE | VECTOR |
| Element nodal | ELEMENT | VECTOR |
| Element nodal moments | ELEMENT | VECTOR |
| point loads | NODE | VECTOR |
| stress | ELEMENT | TENSOR3-D |
| elastic strain | ELEMENT | TENSOR3-D |
| plastic strain | ELEMENT | TENSOR3-D |
| creep strain | ELEMENT | TENSOR3-D |
| thermal strain | ELEMENT | TENSOR3-D |
| swelling strain | ELEMENT | SCALAR |
| direct von Mises strain: elastic | ELEMENT | SCALAR |
| direct von Mises strain: plastic | ELEMENT | SCALAR |
| direct von Mises strain: creep | ELEMENT | SCALAR |
| direct von Mises strain: thermal | ELEMENT | SCALAR |
| pressure | ELEMENT | SCALAR |
| nonlinear: equivalent plastic stress | ELEMENT | SCALAR |
| nonlinear: stress state ratio | ELEMENT | SCALAR |
| nonlinear: hydrostatic pressure | ELEMENT | SCALAR |
| nonlinear: equivalent plastic strain | ELEMENT | SCALAR |
| energy: plastic work | ELEMENT | SCALAR |
| energy: plastic state variable | ELEMENT | SCALAR |
| energy: strain energy | ELEMENT | SCALAR |
| energy: kinetic energy | ELEMENT | SCALAR |
| geometry: element volume | ELEMENT | SCALAR |
| CONTACT48,49,52,178 Elements | ||
| contact: gap status | ELEMENT | SCALAR |
| contact: gap size | ELEMENT | SCALAR |
| contact: normal force | ELEMENT | SCALAR |
| contact: shear force | ELEMENT | SCALAR |
| CONTACT171,172,173,174 Elements | ||
| contact: status | ELEMENT | SCALAR |
| contact: penetration | ELEMENT | SCALAR |
| contact: pressure | ELEMENT | SCALAR |
| contact: friction stress | ELEMENT | SCALAR |
| contact: total stress | ELEMENT | SCALAR |
| contact: sliding distance | ELEMENT | SCALAR |
| contact: gap distance | ELEMENT | SCALAR |
| contact: heat flux at cont. surf. | ELEMENT | SCALAR |
| Composite Elements | ||
| Failure criteria(PFC): MAX | ELEMENT | SCALAR |
| Failure criteria(PFC): FT | ELEMENT | SCALAR |
| Failure criteria(PFC): FC | ELEMENT | SCALAR |
| Failure criteria(PFC): MT | ELEMENT | SCALAR |
| Failure criteria(PFC): MC | ELEMENT | ELEMENT |
| Thermal | ||
| Body temperature | ELEMENT | SCALAR |
| temperature | NODE | SCALAR |
| thermal flux | ELEMENT | VECTOR |
| Electromagnetic | ||
| Electromagnetic force | NODE | SCALAR |
| Electric potential | NODE | SCALAR |
| Current | NODE | SCALAR |
| Magnetic vector potential | NODE | VECTOR |
| Magnetic flux density | ELEMENT | VECTOR |
| Current density | ELEMENT | VECTOR |
| Magnetic force | ELEMENT | VECTOR |
| thermal gradient | ELEMENT | VECTOR |
| heat flow | ELEMENT | SCALAR |
| heat generation | ELEMENT | SCALAR |
| energy: thermal energy | ELEMENT | SCALAR |
| reaction solutions: heat flow | NODE | SCALAR |
| reaction solutions: electric current | NODE | SCALAR |
- HyperViewは、バージョン2022R1、2019R3、およびそれ以前のANSYSのANSYSの構造、熱、および電磁結果をサポートしています。
- ANSYSの結果ファイルからモデル情報を直接抽出できます。ANSYSの.cdbファイルから抽出することもできます。モデルを読み込む際は、Load modelオプションでANSYS .rst、.cdb、または.rmgファイルを指定できます。ただし、Load resultsオプションでは、ANSYS .rstファイルを指定する必要があります。
- HyperViewは、6つのひずみ成分からフォンミーゼスひずみを計算します。この計算では、弾性ひずみと熱ひずみには0.3というポアソン比が使用され、塑性ひずみとクリープひずみには0.5というポアソン比が使用されます。これらのフォンミーゼスひずみ値は、Elastic strain、Plastic strain、Creep strain、Thermal strainというデータ名の、von Misesというサブデータタイプで使用可能です。
- ANSYS 6.0以降のバージョンの結果ファイルには、フォンミーゼスひずみ値が含まれています。HyperViewは、これらのフォンミーゼスひずみ値を抽出し、これらの値はDirect von Mises strainというデータ名で使用できます。Direct von Mises strainオプションを使用することをお勧めします。von Mises strainオプションは、Tensor Plotパネルでも、Elastric strain、Plastic strain、Creep strain、Thermal strainという結果タイプを通じて使用できますが、HyperViewのフォンミーゼスひずみ計算で適用される数値的精度により、Direct von Mises strainオプションと比べて結果がわずかに異なる可能性があります。
- displacements、rotations、reaction forces、reaction moments(NODE結果タイプ)というデータタイプは、1D、2D、3Dのすべての要素でサポートされます。
- ELEMENTの結果(応力やひずみなど)は、常にグローバル直交座標系に表示されます。
- SHELL要素については、HyperViewは上層と下層の結果をサポートしています。
- 接触の結果がサポートされている要素は、CONTACT48、CONTACT49、CONTACT52、CONTACT171、CONTACT172、CONTACT173、CONTACT174です。
- 以下の要素は、HyperView ANSYS Readerでサポートされています:
LINK1、PLANE2、BEAM3、BEAM4、SOLID5、LINK8、INFIN9、LINK10、CONTAC12、PLANE13、COMBIN14、PIPE16、PIPE18、SURF19、PIPE20、MASS21、SURF22、BEAM23、BEAM24、PLANE25、MATRIX27、SHELL28、FLUID29、FLUID30、LINK31、LINK32、LINK33、LINK34、PLANE35、COMBIN39、COMBIN40、SHELL41、PLANE42、SHELL43、BEAM44、SOLID45、SOLID46、CONTAC48、CONTAC49、SHELL51、CONTAC52、PLANE53、BEAM54、PLANE55、HYPER56、SHELL57、HYPER58、PIPE60、SHELL61、SOLID62、SHELL63、SOLID64、PLANE67、LINK68、SOLID69、SOLID70、MASS71、SOLID72、SOLID73、PLANE75、PLANE77、PLANE78、FLUID80、PLANE82、PLANE83、PLANE83、HYPER86、SOLID87、VISCO88、VISCO89、SOLID90、SHELL91、SOLID92、SHELL93、SOLID95、SOLID96、SOLID97、SOLID98、SHELL99、VISCO107、INFIN111、SOLID117、HF118、HF119、HF120、SHELL 131、SHELL 132、SHELL143、PLANE145、PLANE146、SOLID147、SOLID148、SHELL150、SURF151、SURF152、SURF153、SURF154、SHELL157、PLANE162、SHELL163、SOLID164、SOLID168、TARGE169、TARGE170、CONTA171、CONTA172、CONTA173、CONTA174、CONTA175、CONTA178、PRETS179、LINK180、SHELL181、PLANE182、PLANE183、MPC 184、SOLID185、SOLID186、SOLID187、BEAM188、BEAM189、SOLSH190、SOLID191、SHELL208、SHELL209、FLUID220、FLUID221、SOLID227、SOLID278、SOLID279、SHELL281、SOLID285、PIPE288、PIPE289、ELBOW290、SURF251、SURF252。
- ANSYS ETABLEの結果のサポート:ANSYS ETABLEの結果がサポートされているのは、次の要素のみです - BEAM4、PLANE42、BEAM44、SOLID45、SHELL57、SHELL63、SHELL93、SOLID95、SHELL99、SHELL181、BEAM188、FLUID116、LINK31、LINK 32、LINK33、LINK34、LINK71、CONTACT170、CONTACT 173、SOLID70、SOLID226、SOLID227、SOLID87、SOLID90、SOLID185-SOLID186、SOLID187、PLANE55、PLANE13、PLANE223、PLANE35、PLANE77、PLANE182、PLANE183、SHELL281、SURF151、SURF152、SURF251、SURF252。ETABLEの結果をポスト処理するには、ANSYSソルバーのマニュアルに要素タイプごとに記載されているETABLE結果リストの下の結果タイプのアイテム名とシーケンス番号を把握しておく必要があります。
- 複合材定義がREALSETSまたはSECDATAにある場合は、HyperViewで複合材要素がサポートされます。HyperViewは、次の複合材要素について、すべての層の結果をポスト処理できます – SOLID46、SELL99、SHELL91、SHELL131、SHELL132、SOLID191、SHELL181、SOLID185、SOLID186、SOLSH190、SHELL208、SHELL209、SOLID278、SOLID279、SHELL281。
- HyperViewは、RSPLITコマンドから生成された.rstファイルをサポートしています。
- 以下の制限事項が当てはまります:
- 応力やひずみなどの要素結果は、LINK1などのANSYS 1D要素ではサポートされていません。要素結果は、2Dおよび3D要素ではサポートされています。
- 上記以外の複合材要素の結果はサポートされています。
- モデル内のいくつかの節点が局所座標系内で回転された後に、その局所座標系が削除された場合は、正しくないアニメーションプロットが生成されます。
- ETABLEの結果は、ANSYSバージョン9.0以降の出力ファイルでのみ使用できます。
