*MAT_001 (ELASTIC)
LS-DYNA Input Interface KeywordDefines an isotropic, linear elastic material using Hooke’s law.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_001 or *MAT_ELASTIC
mat_ID ρi E υ
Definition
mat_ID Material identifier.
(Integer)
ρi Initial density.
(Real)
[kgm3]
E Young’s modulus.
(Real)
[Pa]
υ Poisson’s ratio.
Default = 0 (Real)
  1. This keyword maps to /MAT/LAW1 (ELAST).
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
