*MAT_169 (ARUP_ADHESIVE)
LS-DYNA Input Interface KeywordDefines adhesive bonding material.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_169 or *MAT_ARUP_ADHESIVE | |||||||
| mat_ID | E | v | TENMAX | GCTEN | SHRMAX | GCSHR | |
| PWRT | PWRS | ||||||
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| E | Young’s modulus. (Real) |
| v | Poisson's coefficient. (Real) |
| TENMAX | Yield stress in tension. (Real) |
| GCTEN | Energy per unit area for bond to fail in
tension. (Real) |
| SHRMAX | Yield stress in shear. (Real) |
| GCSHR | Energy per unit area for bond to fail in
shear. (Real) |
| PWRT | Exponent value for failure in tension. (Real) |
| PWRS | Exponent value for failure in shear. (Real) |
- This keyword maps to /MAT/LAW83, /FAIL/SNCONNECT, and /PROP/TYPE43 (CONNECT).
- The material is fully compressible in the vertical direction from solid element face 1 to face 2.
- The tension stiffness is in the vertical direction and shear stiffness is perpendicular to the vertical direction.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
