Default Streamlines Generated from Inlet Not Visible in Certain Regions
Condition
If you have a coarse voxel resolution, it can cause streamlines to be less detectable. Default streamline density is dependent on voxel mesh resolution.
Remedy
You can create local streamlines if the simulation has produced an inadequate amount.
