Boolean
Create a new part by using one set of solids to edit another set of solids.
The Boolean tools work on both geometry and mesh parts.
Combine Parts
Combine two individual objects or two sets of objects.
On the Geometry ribbon, select the tool.
- Select two or more parts. The first part selected is considered the target.
Click Apply
on the guide bar.
Subtract Parts
Carve out one set of solid objects from another set of solid objects.
- Targets are the set of objects being carved.
- Tools are the set of objects doing the carving.
- A guidebar appears with Targets automatically selected. Select one or more solid objects.
- Press Tab or click Tools, and then select one or more solid objects.
- Optional: To keep the tools in the final result, select Keep Tools.
Click Apply
on the guide bar.
Intersect Parts
Retain only the intersecting portions of two sets of solid objects.
- Targets are the first set of objects.
- Tools are the second set of objects.
Keyboard Shortcuts & Mouse Controls
To | Do this |
Select Tools | Tab |
Add to or remove from the selection | Ctrl |
Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
