area |
Hexa (Contact) |
hexa (area tie), adhesive (shell gap) |
area |
Hexa (Rigid) |
adhesive |
area |
Spring (Contact) |
type2(adhesive spring) |
seam |
Beam (Contact) |
mat196 |
seam |
Hexa (Contact) |
hexa (seam tie), hexa (adhesive contact), HC Glue
Mastic sealer, HC glue spot sealer, HC glue glass
adhesive, hexa (Tapered T) |
seam |
Hexa (HAZ) |
hexa imprint (adhesive-contact), hexa (tapered
T), hexa (RBE2-RBE3) |
seam |
Hexa (Rigid) |
hexa (adhesive), hexa (tapered T) |
seam |
Penta (HAZ) |
penta imprint (adhesive-contact) T |
seam |
Seam (Vectors) |
seam (vectors) |
seam |
Seam Quad |
seam quad LTB, Seam-quad (angled+capped+L),
Seam-quad (angled+capped+L), Seam-quad (vertical +
angled), Seam-quad (angled) |
seam |
Seam Rigid |
seam rigid LTB |
seam |
Spring (Contact) |
type2(spring single row), type2(spring multiple
row) |
spot |
Beam (Contact) |
Mat100, Mat196, rod(spot tie), HC beam spotweld,
HC glue, HC glue structural adhesive, HC welding
line, HC hemming |
spot |
Beam (Rigid) |
Bush, cbar (rigid) |
spot |
Cfast (General) |
cfast_elem (GA-GB), cfast_elem (GS), cfast_prop
(GA-GB), cfast_prop (GS) |
spot |
Fastener (Coincident) |
Fastener |
spot |
Fastener (Nodes) |
fastener nodes |
spot |
Fastener (Noncoincident) |
fastener noncoincident |
spot |
Hexa (Contact) |
mat100(hexa), hexa (spot tie), HC Hexa
Spotweld |
spot |
Hexa (HAZ) |
hexa nugget, acm (shell gap contact +
coating) |
spot |
Hexa (Imprint) |
acm (shell gap + coating) |
spot |
Hexa (Rigid) |
acm (general) |
spot |
Spring (Contact) |
type2(spring), cbush (spot tie) |
spot |
Spring (Rigid) |
sealing, bush, rbe3-cbush-rbe3, rbe3-celas-rbe3,
cbush (rigid) |
