Post
Enhancements
Beam Stress
Removed the loadcase selection inside the tool, and now uses the loadcase selection from the Results Browser.
Plot Control Entities
  • The modelsubcase data name has been added to the subcase entity to refer to the loadcases from an analysis set up.
  • The complex format has been added to the vector, tensor, and deformation plots.
Results Query Tools
  • Support for the "last" identifier for the step index in the XML definition instead of a specific ID.
  • User Systems added to the available selection for Abaqus UP.
  • An option has been added to run the XML configuration file when a model and results are available in the HyperMesh database.
  • Dedicated icon added to launch the Derived Load Case workflow has been added.
Resolved Issues
  • Memory build up issue on plot control definition using explicit selection of multiple components.
  • Sorting by entity ID on Results Query.
  • Slow frame rate on simultaneous plot of deformation and vector/tensor.
  • Graphics cleanup on marker plot.
  • Resolution of crash when shrink elements on with vector/deformation plot.
  • Decoupling of graphic and math engine in the Free Body Plot control. Changing displayed components or arrow size no longer reevaluate the free body section forces.
