hwISession ApplyReport
Applies a report.
hwISession_handle ApplyReport report_name, mode, autofit, report_colors, num_params, params
Tcl Query
- report_name
- The name of the report (for example, "rep_def_1").
- mode
            - overlay
- Overlay the report onto the current session.
- append
- Append the report to the current session.
- replace
- Replace the current report.
- autofit
            - true
- Autofit plots.
- false
- Do not autofit plots.
- report_colors
            - true
- Use report colors.
- false
- Do not use report colors.
- num_params
- The number of parameters.
- params
- Additional argument for each *Parameter() statement in the report (report_name).
sess1 LoadReport bumper.tpl
set autofit false
set report_colors true
sess1 ApplyReport "rep_def_1" append $autofit $report_colors 1 bumper.d3plotError
Success (0) or an error code.
