hwISession RegisterExternalFunction
Registers the given external function.
hwISession_handle RegisterExternalFunction filename, function_name, num_arguments
Tcl Query
- filename
- The name of the dll or shared object file to be registered.
- function_name
- The name of the function.
- num_arguments
- The number of arguments.
mySessionName PublishSession myReportName 20
Error
Success (0) or an error code.
