hwISession CaptureAnimationByWindow
Creates a video file of a window on the current page.
hwISession_handle CaptureAnimationByWindow win_id, type, filename, left, top, right, bottom, dimension_type, width, height
Tcl Query
- win_id
- The ID of the window which needs to be captured.
- type
- The type of file that you want the captured movie to be saved as. The available file types are: AVI, AMF, and GIF (one file contains the entire animation) or PNG, JPEG, BMP, and TIFF (a numbered series of still image files comprising the entire animation).
- filename
- The file name of the captured video.
- left
- The coordinate of the left side of the capture region, in screen percentage (a decimal between 0 and 1).
- top
- The coordinate of the top of the capture region, in screen percentage (a decimal between 0 and 1).
- right
- The coordinate of the right side of the capture region, in screen percentage (a decimal between 0 and 1).
- bottom
- The coordinate of the bottom of the capture region, in screen percentage (a decimal between 0 and 1).
- dimension_type
- Specifies the width and height units of the final animation, which can be in percent or pixels.
- width
- The width of the captured video in percent/pixels.
- height
- The height of the captured video in percent/pixels.
hwi GetSessionHandle sess
sess CaptureAnimationByWindow 0 gif Video.gif 0.1 0.1 0.9 0.9 percent 150 150;
sess CaptureAnimationByWindow 0 avi Video.avi 0.2 0.2 0.8 0.8 pixels 1280 960;
sess CaptureAnimationByWindow 1 png Video.png 0 0 1 1 pixels 800 600;
Error
Success (0) or an error code.
