hwISession SetUserVariable
Associates a value to a variable on the session level.
hwISession_handle SetUserVariable variable, value
Tcl Modify
- variable
- The variable name associated with the session level.
- value
- The value associated with the variable.
mySessionName SetUserVariable last_run run_5Error
Success (0) or an error code.
