hwISession RegisterImportTemplate
Registers the given import template.
hwISession_handle RegisterImportTemplate filename, type, ext
Tcl Query
- filename
- The name of the template to be registered.
- type (Optional)
- The type of template to be registered. This string, if specified, appears in the drop-down combo box in the File dialog.
- ext (Optional)
- If specified, this is the extension actually used as a filter if the specified type is chosen in the File dialog. Also, the registered import template will be among the first tried when files with this extension are imported (accelerating the file recognition process).
mySessionName RegisterImportTemplate myTemplate "New Import Template (*.imp)"  *.IMP Error
Success (0) or an error code.
