hwISession CaptureDesktop
Captures the entire desktop to an image file.
hwISession_handle CaptureDesktop type, filename, (quality)
Tcl
This command captures the entire desktop to an image file.
- type
- The file type that you want to save the captured image as. The file type options include: BMP, JPEG, TIFF, PNG or saved to the clipboard.
- filename
- The file name that you want to call the captured image.
- (quality) (Optional)
- The level of quality or compression that you want to make the image.
hwi GetSessionHandle sess;
sess CaptureDesktop png MyPicture.png;Error
Returns success (0) or an error code.
Keywords
Tcl
Create
