hwISession CaptureAnimationByArea
Creates a movie file by animating the current page, allowing you to first draw a box and select a sub-rectangle of the page for capture.
hwISession_handle CaptureAnimationByArea filetype, filename, left, top, right, bottom, [dimension_type, width, height]
Tcl Query
This command uses the current values for options found in the hwIAVIExportOptions or hwIAMFExportOptions object.
- filetype
- Indicates the format of the output file. The animated formats can be "avi", "amf", and "gif" (one file contains the entire animation) or "png", "jpeg", "bmp" and "tiff" (a numbered series of still image files comprising the entire animation).
- filename
- The name of the file to be created.
- left
- The coordinate of the left side of the capture region, in screen percentage.
- top
- The coordinate of the top of the capture region, in screen percentage.
- right
- The coordinate of the right side of the capture region, in screen percentage.
- bottom
- The coordinate of the bottom of the capture region, in screen percentage.
- dimension_type
- Specifies the width and height units of the final animation, which can be in percent
            or pixels.Note: If you specify a dimension_type, you MUST specify BOTH width and height (see below).
- width
- The number of width units of the final captured animation.
- height
- The number of height units of the final captured animation.
mySessionName GetGIFExportOptionsHandle myGIF
myGIF SetSize 99
myGIF SetDelay 0.5
mySessionName CaptureAnimationByArea gif c:/temp/fun.gif 0 0 1050 450
mySessionName CaptureAnimationByArea gif c:/temp/fun_75.gif 0 0 1050 450 percent 75 75Error
Success (0) or an error code.
