Create Fillet/Seam Welds
Create fillet and seam weld connections between parts in your assembly.
                On the Connections workbench toolbar, click
 (Create seam weld).
             - In the dialog, define the Section size (the length measured from the toe to the root of the weld).
                Define the Minimum length.
                Note: Any geometric edges found that are less than the minimum weld length will not receive a weld.
 - Optional:
                Activate the Intermittent weld checkbox to specify
                    intermittent welds.
                Note: Two parameters, weld pitch and weld segment length, are required for intermittent welds. the pitch must be greater than the segment length.
Figure 1. - Find welds using one of the following methods:
 - Click OK.
