Remove a published application definition from the global application definition
list.
Note: Only administrator can remove the global application definition.
The administrator who has published the application definition can remove the
application definition from the global list.
Click .
Select App Composer .
The Applications panel lists all the application definitions that is
created, shared and published.
Figure 1. App Composer
The indicates that it is a shared application
definition.
The indicates that it is a published application
definition which is global app def available to all the
users.
Click next to the application definition that you want to
unpublish.
Select Unpublish in the context menu.
Figure 2. Unpublish Application Definition
A notification is displayed.
The application list is updated and
is removed.
Figure 3. Applications List
