Edit an Application Definition
Edit and save the application definitions.
The Applications panel lists all the application definitions that you have created. You can edit and save the application definitions.
New features available in Altair Access™ Web.
Use Access Web to submit jobs to a Workload Manager.
Video tutorials to help you get started with Altair Access Web.
Access Web is supported on the following web browsers.
Login to Access Web so that you can submit and monitor jobs.
Schedule jobs to run on an HPC cluster by submitting them to the Workload Manager.
Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view a list of job files, or perform job actions.
Move job to a different queue, terminate, remove unwanted jobs, resubmit and download jobs.
Manage the jobs files by creating a new file, remove unwanted job files, downloading job files, viewing or editing a file.
Create, view and remove job profiles.
Add, update, or delete HPC clusters.
Create, manage, and navigate to your bookmark.
Organize and manage your job files.
Flexibility when you view the list view in Files and Jobs tab.
Create a remote desktops by submitting an interactive job and manage open remote desktops.
Visualize plots and animations from the result files.
View site specific pages in Access Web.
View notification messages that are displayed for various events.
Access Web provides an easy way to create a user defined application definition (app def) using the App Composer.
Overview of application definition composer components.
Create your own solver application definitions using the Basic-SMP or Basic-MPI starter template.
Create your own Remote Desktops application definitions using the Desktop-Linux or Desktop-Windows starter template.
Publish a local application definition to the administrator to make it as a global application definition.
Publish a local application definition that is shared by the user as a global application definition.
Remove a published application definition from the global application definition list.
Share the application definition that you have created to your team members.
View the shared application definition and save it as a local application definition.
Clone or copy an application definition that is created.
Delete unwanted application definition.
Set the user Access Web preferences.
View the Access Web Application Version.
View information about other Altair products such as Access Desktop and Access Mobile.
Create roles and add users to these roles to grant and restrict access to the various features of Access Web.
Audit Log provides an easy way to view record of actions happening in Access Web.
Change the remote desktop expiry time globally in the Access Web portal.
Share audit logs with Altair for troubleshooting Access Web.
Provide feedback from the Access Web application.
Change the password that you use to login to the machine hosting Access Web.
Provide a password once eliminating the need to continually authenticate to the Windows HPC complex.
