Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
Move a folder or a file from one location to another within a server.
Tip: You can also use Cut and Paste option to move a folder or a file
from one location to another.
Click the Files tab located in the upper left-hand of the page.
Using the file system tree on the left, navigate to the location where you want
to move the folder or a file.
Select the folder or a file that you want to move.
Tip: You can select multiple folder or a file to move.
Select the first folder or a file by clicking its name and hold down
CTRL and select each folder or a file by clicking its name.
Drag the selected file to the destination.
Tip:
You can also move the folder in the file system tree on the left
by dragging the folder from one location to another.
