Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
Tail the job files to view the progress of the job.
Depending on the state of the job, the job files that you are viewing may be stored
on either the local desktop or on the remote PAS
server.
While a job is running results files are maintained on the remote PAS server. These files can be displayed by viewing the
contents of the Running Folder. Once the job completes, the
job results files are written to the Output folder in
Job Summary.
Click the Jobs tab located in the upper left-hand of the page.
The job monitoring page is displayed with the list of jobs that are
submitted.
Perform one of the following options:
Click the running job name from the list.
Right click the running job and click the View Details
from the context menu.
The Job Summary tab is displayed. Figure 1. Job Summary Tab
Click Running Folder tab.
The Job Running Folder tab is displayed. Figure 2. Job Running Folder Tab
Choose one of the following options:
If you want to open the file in the default application,
double-click the file.
If you want to open the file in the default application, right-click the
file and select Open in the context menu.
If you want to choose an application and to set a default application to
open the file, right-click the file and select Open
With.
Tip: To set a default application to open a file based on the file
extension, then select Always Use this
check-box.
The file will be opened in the application: Figure 3. Opened File
Click located in the upper right-hand of the page.
The file will be displayed with the tailing options like Play, Pause, and Stop.
Figure 4. Tailing the File
