Delete a Job Profile
Remove a job profile that is no longer needed.
Click the Jobs tab located in the upper left-hand of the
page.
A list of applications are displayed at the top of the Job Monitoring page.
Figure 1. List of Applications/Solvers -
Double-click an application.
A job submission form is displayed.
Figure 2. Saved Job Profile -
Click
next to Generic Profile to view the list of saved Profiles.
Figure 3. Generic ProfileNote: By default, only Generic Profile and Last Submitted profile will be listed if there are no saved profiles.The list of profiles is displayed.
Figure 4. Saved Profiles List -
Select the Profile from the drop-down list.
Figure 5. Select Saved ProfileThe selected profile job submission form with the pre-populated argument is displayed.
Figure 6. Saved Profile Job Submission FormNote: The profile delete icon () and rename icon (
) will be enabled once you select a saved profile from the list.
Click
next to the profile name.
Note: If you delete a profile that is set as default profile, then after deleting the profile the default is set to the Generic Profile.The Delete Profile dialog box is displayed.
Figure 7. Delete Profile - Click Yes to delete the profile.
