Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
RVS supports plotting of visualization data stored
using CSV (comma-separated values) files.
To plot a CSV file, have your CSV files uploaded in the
Files tab.
The CSV plot file contains plot result data in the form of values with comma
separated.
You can apply a template to view your CSV plot result and also create a
new template using the CSV plot parameters.
If you have a default template
set for a CSV plot file, you will be navigated to the plot result if the default
template is valid for the selected result file. If a template cannot be applied to a
result file, a message is displayed to select another valid template.
Right-click a CSV file and then click Open With > Plot TOC.
The Table of Contents (TOC) pop-up screen is displayed. Figure 1. Table of Contents
The variables of the plot data values are displaying under Column
name.
Optional: Enter a name for Plot Title.
Optional: Enter a name for X-Axis Title.
Optional: Enter a name for Y-Axis Title.
Optional: Enter a name for Template Name if you wish to save the following
parameter selections as a Plot Template.
The first time a plot is created from a job results folder, the Generic
Template is selected.
For X-Axis parameters, to choose different parameters click located to the right of the field.
Note: By default, the first entry in the result parameters list is considered
for a plot.
Select the variables as Y-axis parameters.
Note: The CSV file details are displayed as Column names to select the
plot parameters.
Choose one of the following options:
Click Set Template as Default check box to set this template as a
default template.
