Manage Plot Templates
Create, modify, and remove plot templates.
RVS validates the template when selected to apply for the selected plot result file. If the template matches the result file, the plot parameters are displayed on the plot TOC fields on the right pane. If a template cannot be applied to a result file, a message is displayed to select another valid template.
If a default template is set for a result file then RVS will display the plot result directly. If the set default template doesn't match the result file, the plot TOC is displayed with a message to select another valid template.
