Plot Aero Coefficients
Use the Plot Aero Coefficients tool to generate a 2D graph of the lift, drag, and side forces acting on the body in the wind tunnel.
- Right-click on the legends, axes, or individual plots to edit the display properties.
- You can also view aero coefficients by selecting a job in the Run Status or Run History dialog and clicking Plot Results.
