Visualize Results Use the Show Analysis Results tool to open a results file in HyperMesh CFD Post. Before you begin, use the Run VWT tool to submit an analysis. From the Run tools, click the Show Analysis Results tool. Figure 1. Select a results file then click Open. The analysis results are loaded in HyperMesh CFD Post.
