2023
Prepare your model and run the simulation.
Prepare your model for a general AcuSolve simulation.
Set up the simulation model, materials, domains, and boundaries.
Define the simulation domain.
View new features for HyperMesh CFD 2023.
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
Use the Convert tool to convert entire models between data types.
Manage CAD, FE, and 2D parametric sketch geometry.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Define global simulation settings, materials, and any multipliers or parameters.
Use the Material tool to assign materials to solid bodies.
Use the Thin tool to define thin thermal layers on surfaces and assign material properties.
Use the Porous tool and its satellite icons to define Cartesian, cylindrical, and spherical porosity on solid bodies.
Use the Sources tools to specify a collection of body forces (heat, momentum, or species) within solid bodies.
Use the Reference Frame tool to define rotating reference frames on solid bodies or surfaces.
Use the Heat Exchanger tool to specify heat exchanger components for a solid.
Use the Fan Component tool to model a fan by specifying fan characteristics on a solid.
Define surface boundary conditions.
Define radiation conditions and create emissivity models.
Define direct, derived, and constrained mesh motion.
Define output conditions, run the simulation, and view the results.
AcuTrace is particle tracer that runs as a post-processor to AcuSolve.
Prepare your model for wind tunnel analysis using ultraFluidX.
Post-process the simulation results by creating visualizations and measurements.
Automate simulation processes with templates and utility scripts.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
More resources for AcuSolve and ultraFluidX solvers.
