Use the Material Library tool to create, edit, delete, and import/export fluid, solid, or immiscible multiphase materials. Once defined, these
materials can be referenced in any domain.
Use the Multipliers tool to create, edit, and delete multiplier functions. Multiplier or ramp functions are used to multiply or ramp
variables while defining boundaries, radiation, and mesh conditions.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Define Materials
Use the Material Library tool to create, edit, delete, and import/export fluid, solid, or immiscible multiphase materials. Once defined, these materials can be referenced in any domain.
Define Parameters
Use the Parameters tool to create, delete, and import/export parameters.
Define Multiplier Functions
Use the Multipliers tool to create, edit, and delete multiplier functions. Multiplier or ramp functions are used to multiply or ramp variables while defining boundaries, radiation, and mesh conditions.
