Define Turbulence Source Regions
Use the Turbulence tool to generate turbulence source regions.
From the Setup ribbon, click the
Turbulence tool.
Figure 1. -
In the modeling window, select a part on which you
would like to place the turbulence source.
A turbulence source consisting of a turbulence generating plane and a mesh control box is created.
Re-size the mesh control box by completing one of the following:
- Click and drag a face of the mesh control box.
Figure 2. - In the microdialog, click
and adjust the Length, Width, and
Height.
Note: Resizing the mesh control box automatically re-sizes the plane. - Click and drag a face of the mesh control box.
Click
and use the graphical manipulators to move the turbulence source.
Figure 3. - Optional:
and define turbulence source region settings.
Set the Turbulence Intensity.
This controls the intensity of the eddies created on the turbulence plane.
Adjust Refinement Level of the mesh box.
The element size that corresponds to this refinement level is shown below.Note: The refinement level automatically adjusts the default values for Plane Offset, Eddy Length Scale, and Number of Eddies.
- Adjust the Plane Offset to adjust the gap between the turbulence source plane and box.
Adjust the Eddy Length Scale.
This controls the size of the eddies generated on the turbulence plane.
Adjust the Number of Eddies.
This is the total number of eddies generated on the turbulence plane. Eddies are placed randomly on the plane.
Figure 4.Tip: After changing a value in the microdialog, click
next to the edited value to reset it. -
- Optional:
Use a turbulence source without mesh control.
- In the microdialog, disable the Mesh Control check box to remove the mesh control box.
Click an edge of the plane and use the graphical manipulators to
re-size the selected edge.
Figure 5. -
Click
the plane.
Figure 6.
From the guide bar, complete one of the following:
- Select
to confirm your selection and continue creating
turbulence source regions. - Select
to
confirm your selection and exit the tool.
- Select
