hwIReportTemplate Apply
Applies the report template settings and draws the report.
hwIReportTemplate_handle Apply mode, autofit, autocolor, autoposition, (instance)
Tcl Modify
This command applies the report template settings input and draws the report.
mode
A string representing the mode that the report should be in. Options for the mode variable include: overlay, replace, or append.
autofit
A true or false value. If you want the plot of the report (if there is a plot) to be autofit to its curves, true must be input. Otherwise, input false.
autocolor
A true or false value. If you want to use the colors preset by the report, input true. Otherwise, input false.
autoposition
A true or false value. If you want to place notes in a preset position made by the report, input true. If you do not want notes autopositioned, input false.
(instance) (Optional)
This only affects the report if there is more than one appended report, followed by an overlay. The input is a number which determines which appended report the overlay report is applied to.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr TextEditor;
mgr Apply overlay true true false 2;
Error
Keywords
Tcl
Report Template
Template
Modify
