hwIReportTemplate GetNumberOfParameters
Finds the number of parameters in the report.
hwIReportTemplate_handle GetNumberOfParameters
Tcl Query
This command returns the number of parameters in the report. A parameter is a value or file of data that is input using the report template.
hwi GetSessionHandle sess;
sess GetReportTemplateHandle rep 1;
rep GetNumberOfParameters;
Error
Success (the number of parameters) or an error message is returned.
Keywords
Tcl
Report Template
Template
Query
