tables
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Writes bool column data to a table.
Writes double column data to a table.
Writes entity ID column data to a table.
Writes float column data to a table.
Writes integer column data to a table.
Writes string column data to a table.
Writes triple column data to a table.
Writes unsigned integer column data to a table.
Writes a table entity.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
ON THIS PAGE
ON THIS PAGE
