elements
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Determines the number of nodes associated with the configuration of the element.
Writes a 2-noded bar with property idpool to HyperMesh using a vector to define the bar local x axis.
Writes a 2-noded bar element with property idpool to HyperMesh using a node to define the local bar y axis.
Writes a bar element with property idpool to HyperMesh using a node to define the local bar z axis.
Writes a 3-noded bar with property idpool to HyperMesh using a vector to define the bar local x axis.
Writes a 3-noded bar element with property idpool to HyperMesh using a node to define the local bar y axis.
Writes a gap element with property idpool to HyperMesh.
Writes a joint element with property idpool to HyperMesh.
Writes a mass element with property idpool to the HyperMesh database.
Writes a rod element with property idpool to HyperMesh.
Writes a 2-noded bar to HyperMesh using a vector to define the bar local x axis.
Writes a 2-noded bar element to HyperMesh using a node to define the local bar y axis.
Writes a bar element to HyperMesh using a node to define the local bar z axis.
Writes a 3-noded bar to HyperMesh using a vector to define the bar local x axis.
Writes a 3-noded bar element to HyperMesh using a node to define the local bar y axis.
Writes a gap element to HyperMesh.
Creates a main or secondary element from an existing element in HyperMesh.
Writes an eight-noded brick solid element to HyperMesh.
Writes a twenty-noded brick solid element to HyperMesh.
Writes a joint element to HyperMesh.
Writes a three-noded main interface element to HyperMesh.
Writes a four-noded main interface element to HyperMesh.
Writes a mass element to the HyperMesh database.
Writes a five-noded solid pyramid element to HyperMesh.
Writes a six-noded wedge solid element to HyperMesh.
Writes a thirteen-noded, second order solid pyramid element to HyperMesh.
Writes a fifteen-noded wedge solid element to HyperMesh.
Writes a plot element to HyperMesh.
Writes a four-noded quadrilateral shell element to HyperMesh.
Writes an eight-noded quadrilateral shell element to HyperMesh.
Writes an RBE3 element to HyperMesh.
Writes an RBE3 element header to HyperMesh.
Writes the nodes that define the RBE3 element to HyperMesh.
Writes a rigid element to HyperMesh.
Writes a rigid link element to HyperMesh.
Writes a rigid link header to HyperMesh.
Writes the nodes that define the rigid link to HyperMesh.
Writes a rod element to HyperMesh.
Creates a secondary element from an existing element in HyperMesh.
Writes a one-noded secondary interface element to HyperMesh.
Writes a three-noded secondary interface element to HyperMesh.
Writes a four-noded secondary interface element to HyperMesh.
Writes a spring element to HyperMesh.
Writes a four-noded tetrahedral solid element to HyperMesh.
Writes a ten-noded tetrahedral solid element to HyperMesh.
Writes a three-noded triangular shell element to HyperMesh.
Writes a six-noded triangular shell element to HyperMesh.
Writes a weld element to HyperMesh.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
