attributes
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Transfers a double attribute to HyperMesh.
Transfers a double array attribute to HyperMesh.
Transfers a 2-D double array to HyperMesh.
Transfers an entity attribute to HyperMesh.
Transfers an entity array attribute to HyperMesh.
Transfers a 2-D entity array attribute to HyperMesh.
Transfer an integer attribute to HyperMesh.
Transfer an integer array attribute to HyperMesh.
Transfer a 2-D integer array to HyperMesh.
Transfer a string attribute to HyperMesh.
Transfer a string array attribute to HyperMesh.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
ON THIS PAGE
ON THIS PAGE
