surfaces
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Signals the end of a trimming line.
Signals the end of a surface.
Signals the start of an object space line.
Signals the start of a parameter space line.
Signals the start of a trimming line.
Signals the beginning of a surface.
Writes a fixed meshing point for a surface.
Specifies the information for a NURBS surface.
Specifies the information for a plane.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
ON THIS PAGE
ON THIS PAGE
