lines
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Signals the end of a line.
Writes a line to HyperMesh.
Signals the beginning of a line.
Specifies the next segment in the current line as a piecewise cubic spline.
Specifies the next segment in the current line as an elliptical arc.
Specifies the next segment in the current line as a NURBS curve.
Specifies the next segment in the current line as a straight line segment.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
ON THIS PAGE
ON THIS PAGE
