miscellaneous
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Assigns a color to the designated component.
Allows nodes to be transformed to a global coordinate system, based on the local coordinate system.
Allows vectors in a Cartesian, cylindrical, or spherical system to be transformed to a global coordinate system, based on the local system.
Allows vectors to be transformed to a global coordinate system, based on a local coordinate system.
Allows systems, loads, or nodes to be transformed to the global coordinate system, based on the local coordinate system.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
ON THIS PAGE
ON THIS PAGE
