::Update
The above command will display the current value in the mdlOption widget which is set in the value data member.
::model::mdlOption::Update argFrm
MotionView Tcl
- argFrm
- You need to pass the path of the mdlOption widget as the above argument for which you need to display the value.
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
::model::GetHandleFromFullVarname dsms MODEL.DS_MotionSolve_Simopts
set optSimType [::model::mdlOption $colFrm.optSimType dsms "analysis_type"]
pack $optSimType
dsms ReleaseHandle
::model::mdlOption::Update $optSimType
On successful execution of the command, the current value will be displayed.
