::GetLastCollector
This command will be used to get the type of the last collector within the mdlOrientation widget.
::model::mdlOrientation::GetLastCollector argFrm
MotionView Tcl
- argFrm
- You need to pass the path of the mdlOrientation widget as the above argument, from which you need to get the address of the last collector.
::model::GetClientHandle client
client GetModelHandle mod
mod InterpretEntity mrk Marker mrk_0 "\"Marker 0\"" "" ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set ornt [::model::mdlOrientation $colFrm.ornt mrk]
pack $ornt
client ReleaseHandle
mod ReleaseHandle
mrk ReleaseHandle
set col [::model::_private::mdlOrientation::GetLastCollector .test.tmpFrm1.ornt]
tk_messageBox -message "Last collector path: $col"
On successful execution of the command, it will return the address of the last collector widget.
