hwIPreferenceManager LoadPreferenceFile
Reads and loads a script file from within the list of preference files.
hwIPreferenceManager_handle LoadPreferenceFile prefIndex menuName filePath
Tcl
This command reads a script file within the list of preference files and loads the file.
prefIndex
The index (position within the internal list of preference files) of the preference file that you want to load. This is a zero-based index, meaning the positions start at zero, rather than one. Therefore, the first preference file in the list would have an index of zero; the second would have a one, and so on. If you do not know or do not want to supply the index, a -1 must be input.
menuName
The name of a menu that you want to load. A null string, “”, can also be input if you do not know or do not want to input the menu name. If the menu name is supplied, it is used to search for a preference file match.
filePath
The filepath of the desired file (within “” or {} if there are spaces in the filepath) that you want to get the component list for. A null string, “”, can also be input if you do not know the filepath or do not want to input the filepath. If the filepath is supplied, it is used to search for a preference file match.
hwi GetSessionHandle sess;
sess GetPreferenceManagerHandle pref;
pref LoadPreferenceFile;
Error
Keywords
Tcl
Preference Manager
