hwIPreferenceManager RegisterPreferenceFile
Adds the preference file to the internal list of preference files.
hwIPreferenceManager_handle RegisterPreferenceFile menuName filePath isDefault
Tcl
This command reads the preference file to the internal list of preference files.
menuName
The name that you want to call the preference file in the Preference menu.
filePath
The filepath of the desired file (within “” or {}, if there are spaces in the filepath).
isDefault
A true or false value.
true
If you want the preference file to be the default preference file.
false
If you do not want the preference file to be set as the default.
hwi GetSessionHandle sess;
sess GetPreferenceManagerHandle pref;
pref RegisterPreferenceFile MyFile.mvw c:/MyFile.mvw false;
Error
Keywords
Tcl
Preference Manager
