hwIViewControl CircleZoom
Zooms the plot to within the given dimensions.
hwIViewControl_handle CircleZoom min_x, min_y, max_x, max_y
Tcl Query
This command zooms on the graph based on the given dimensions. It differs from ZoomIn or ZoomOut in that it zooms within the specified dimensions rather than a preset zoom. It also differs from Fit in that it zooms based on the user-input dimensions rather than zooming to the curve’s dimensions.
min_x
The minimum value of x. This is the lowest possible value of x on the graph (the most left value). This does not mean that the x axis goes down to this exact x value. It does, however, mean that the displayed portion of the x axis will not stop before this value.
max_x
The maximum value of x. This is the highest possible value of x on the graph (the most right value). This does not mean that the x axis goes up to this exact x value. It does, however, mean that the displayed portion of the x axis will not stop before this value.
min_y
The minimum value of y. This is the lowest value of y on the graph (the bottom most value). This does not mean that the y value goes down to this exact y value. It does, however, mean that the displayed portion of the y axis will not stop before this value.
max_y
The maximum value of y. This is the highest value of y on the graph (the upper most value). This does not mean that the y axis goes up to this exact y value. It does, however, mean that the displayed portion of the y axis will not stop before this value.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot AddCurve;
plot GetCurveHandle c1 1;
c1 GetVectorHandle x1 x;
x1 SetType Math;
x1 SetExpression (0:(10*PI):(PI/2));
c1 GetVectorHandle y1 y;
y1 SetType Math;
y2 SetExpression ((cos(x)*sin(x))/2);
w1 GetViewControlHandle vc;
vc CircleZoom 0 -5 6 5;
plot Draw
Error
If the min_x, min_y, max_x, and max_y values are not all present, an error message is displayed. If the values do not make a rectangle, the zoom will not occur.
Keywords
XY Plot
Tcl
Modify
